소개
If you shutter lens does not seem to operate, these guides will help you find the problem.
필요한 것
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
다른 11명이 해당 안내서를 완성하였습니다.
댓글 6개
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
Nikon coolpix s3100 lens mocking place help my
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
I have same issue it shutter half opens and doesnt open correctly
shailendra - 답글
my LCD screen is stuck on white after after i did this :(
