주요 콘텐츠로 건너뛰기
Nikon Coolpix S3100 disassembly
필요한 것
  1. Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: 1 단계, 이미지 1/3 Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: 1 단계, 이미지 2/3 Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: 1 단계, 이미지 3/3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 disassembly: 2 단계, 이미지 1/2 Nikon Coolpix S3100 disassembly: 2 단계, 이미지 2/2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 disassembly: 3 단계, 이미지 1/2 Nikon Coolpix S3100 disassembly: 3 단계, 이미지 2/2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jorge
회원 가입일: 03/11/15
1,170 평판
안내서 7개 작성하였습니다
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 회원
UCCS-PANKO-S15S2G4
2 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 43
전체 시간: 1,952
