주요 콘텐츠로 건너뛰기
Nikon Coolpix S33 LCD Replacement
필요한 것
  1. Nikon Coolpix S33 LCD Replacement, Back Cover: 1 단계, 이미지 1/2 Nikon Coolpix S33 LCD Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove battery before initiating this step to avoid the possibility of electric shock.
    • Remove all four T5 Torx screws from the exterior of the camera.
    • Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
  2. Nikon Coolpix S33 LCD Replacement: 2 단계, 이미지 1/1
    • Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
  3. Nikon Coolpix S33 LCD Replacement: 3 단계, 이미지 1/2 Nikon Coolpix S33 LCD Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, gently remove the back cover from the camera.
  4. Nikon Coolpix S33 LCD Replacement, LCD: 4 단계, 이미지 1/1
    • Be sure to have followed the steps to remove the Back Cover of your camera before beginning to replace the LCD Screen. This guide will cover just the replacement of the LCD Screen.
    • Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
  5. Nikon Coolpix S33 LCD Replacement: 5 단계, 이미지 1/1
    • Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
    • Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maria Frias
회원 가입일: 02/18/16
564 평판
안내서 4개 작성하였습니다
USF Tampa, Team 16-3, Blackwell Winter 2016 USF Tampa, Team 16-3, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G3
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Good evening
the LCD of the COOLPIX S33 is the same as S3300? I broke in S33 of my son but I can not find the parts.
Thank you
Francesco
Buona sera
l'LCD della coolpix S33 è lo stesso della S3300? mi si è rotto nella S33 di mio figlio ma non trovo il ricambio.
Grazie
Francesco
fenchi71 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 19
전체 시간: 1,887
