주요 콘텐츠로 건너뛰기
Nikon Coolpix S33 Speaker Replacement
필요한 것
  1. Nikon Coolpix S33 Speaker Replacement, Back Cover: 1 단계, 이미지 1/2 Nikon Coolpix S33 Speaker Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove battery before initiating this step to avoid the possibility of electric shock.
    • Remove all four T5 Torx screws from the exterior of the camera.
    • Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
  2. Nikon Coolpix S33 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
  3. Nikon Coolpix S33 Speaker Replacement: 3 단계, 이미지 1/2 Nikon Coolpix S33 Speaker Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, gently remove the back cover from the camera.
  4. Nikon Coolpix S33 Speaker Replacement, LCD: 4 단계, 이미지 1/1
    • Be sure to have followed the steps to remove the Back Cover of your camera before beginning to replace the LCD Screen. This guide will cover just the replacement of the LCD Screen.
    • Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
  5. Nikon Coolpix S33 Speaker Replacement: 5 단계, 이미지 1/1
    • Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
    • Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
  6. Nikon Coolpix S33 Speaker Replacement, Speaker: 6 단계, 이미지 1/2 Nikon Coolpix S33 Speaker Replacement, Speaker: 6 단계, 이미지 2/2
    • Remove the screws. Gently pry off the LCD holder using a plastic opening tool.
  7. Nikon Coolpix S33 Speaker Replacement: 7 단계, 이미지 1/2 Nikon Coolpix S33 Speaker Replacement: 7 단계, 이미지 2/2
    • After removing the LCD holder, you can begin the process of removing the speaker from the camera.
    • Remove the 15'' Phillips screw using a PH#00 screwdriver.
    • Gently pry off the green flap to get access to the speaker port.
  8. Nikon Coolpix S33 Speaker Replacement: 8 단계, 이미지 1/1
    • Gently pull out the speaker using the green and white wires.
    • Disconnect these wires from the motherboard.
결론
Maria Frias
회원 가입일: 02/18/16
564 평판
안내서 4개 작성하였습니다
USF Tampa, Team 16-3, Blackwell Winter 2016 USF Tampa, Team 16-3, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 580
