주요 콘텐츠로 건너뛰기
Nikon Coolpix S3500 Battery and memory card door Replacement
필요한 것
  1. Nikon Coolpix S3500 Battery and memory card door Replacement, Battery and memory card door: 1 단계, 이미지 1/1
    • Take the device in your hand, and hold it with the shutter side of the device facing upward.
  2. Nikon Coolpix S3500 Battery and memory card door Replacement: 2 단계, 이미지 1/1
    • With the shutter still facing up, make sure the battery door is facing your opposite hand.
    • Using your free hand, pick up your new battery door.
  3. Nikon Coolpix S3500 Battery and memory card door Replacement: 3 단계, 이미지 1/1
    • Make sure that the new battery door is groove side up so that the door will slide onto the metal bracket on the device.
  4. Nikon Coolpix S3500 Battery and memory card door Replacement: 4 단계, 이미지 1/1
    • Line up the grooves on the battery door with the metal bracket and press the door towards the device.
    • The battery door is held on by tabs. Make sure that the tabs click into place on the door.
결론
Jordan Rosemeyer
회원 가입일: 10/13/15
491 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 2-1, Blackburne Fall 2015 Sam Houston State, Team 2-1, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 611
