주요 콘텐츠로 건너뛰기
Nikon Coolpix S3500 Rear Buttons Replacement
필요한 것
  1. Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: 1 단계, 이미지 1/2 Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: 1 단계, 이미지 2/2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Rear Buttons  Replacement: 2 단계, 이미지 1/2 Nikon Coolpix S3500 Rear Buttons  Replacement: 2 단계, 이미지 2/2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Rear Buttons  Replacement: 3 단계, 이미지 1/2 Nikon Coolpix S3500 Rear Buttons  Replacement: 3 단계, 이미지 2/2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Rear Buttons  Replacement: 4 단계, 이미지 1/2 Nikon Coolpix S3500 Rear Buttons  Replacement: 4 단계, 이미지 2/2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Rear Buttons  Replacement: 5 단계, 이미지 1/3 Nikon Coolpix S3500 Rear Buttons  Replacement: 5 단계, 이미지 2/3 Nikon Coolpix S3500 Rear Buttons  Replacement: 5 단계, 이미지 3/3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Rear Buttons  Replacement: 6 단계, 이미지 1/2 Nikon Coolpix S3500 Rear Buttons  Replacement: 6 단계, 이미지 2/2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Rear Buttons  Replacement, Rear Buttons: 7 단계, 이미지 1/1
    • Take the rear panel of the device in the palm of your hand with the buttons facing downward.
  8. Nikon Coolpix S3500 Rear Buttons  Replacement: 8 단계, 이미지 1/3 Nikon Coolpix S3500 Rear Buttons  Replacement: 8 단계, 이미지 2/3 Nikon Coolpix S3500 Rear Buttons  Replacement: 8 단계, 이미지 3/3
    • On the back side of the device's rear panel, you will see the plastic brackets that hold the rear function buttons in place.
    • With your other hand, take the pry tool and start working your way around the edge of the buttons
  9. Nikon Coolpix S3500 Rear Buttons  Replacement: 9 단계, 이미지 1/2 Nikon Coolpix S3500 Rear Buttons  Replacement: 9 단계, 이미지 2/2
    • Now, take the hand that was previously holding the pry tool, and finish pulling off the rear function buttons.
결론
Jordan Rosemeyer
회원 가입일: 10/13/15
491 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 2-1, Blackburne Fall 2015 Sam Houston State, Team 2-1, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 420
