주요 콘텐츠로 건너뛰기
Nikon Coolpix S3500 Shutter Release Button Replacement
필요한 것
  1. Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: 1 단계, 이미지 1/2 Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: 1 단계, 이미지 2/2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Shutter Release Button Replacement: 2 단계, 이미지 1/2 Nikon Coolpix S3500 Shutter Release Button Replacement: 2 단계, 이미지 2/2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Shutter Release Button Replacement: 3 단계, 이미지 1/2 Nikon Coolpix S3500 Shutter Release Button Replacement: 3 단계, 이미지 2/2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Shutter Release Button Replacement: 4 단계, 이미지 1/2 Nikon Coolpix S3500 Shutter Release Button Replacement: 4 단계, 이미지 2/2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Shutter Release Button Replacement: 5 단계, 이미지 1/3 Nikon Coolpix S3500 Shutter Release Button Replacement: 5 단계, 이미지 2/3 Nikon Coolpix S3500 Shutter Release Button Replacement: 5 단계, 이미지 3/3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Shutter Release Button Replacement: 6 단계, 이미지 1/2 Nikon Coolpix S3500 Shutter Release Button Replacement: 6 단계, 이미지 2/2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Shutter Release Button Replacement, Shutter Release Button: 7 단계, 이미지 1/1
    • Place the device shutter side down onto your hand.
  8. Nikon Coolpix S3500 Shutter Release Button Replacement: 8 단계, 이미지 1/3 Nikon Coolpix S3500 Shutter Release Button Replacement: 8 단계, 이미지 2/3 Nikon Coolpix S3500 Shutter Release Button Replacement: 8 단계, 이미지 3/3
    • Take the thumb of the hand holding the device and place it on the plastic front panel.
    • Make sure to be gentle so no damage is done to any of the inner components of the device.
    • With your free hand, grip the outer edge of the LCD screen and start to pull the LCD from the front panel of the device.
    • This should cause the two pieces to separate from each other.
  9. Nikon Coolpix S3500 Shutter Release Button Replacement: 9 단계, 이미지 1/2 Nikon Coolpix S3500 Shutter Release Button Replacement: 9 단계, 이미지 2/2
    • Now that the 2 pieces are separated, take your free hand and gently press down on the shutter release button.
    • This should cause the shutter release button to come free from the front panel of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Rosemeyer
회원 가입일: 10/13/15
491 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 2-1, Blackburne Fall 2015 Sam Houston State, Team 2-1, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 625
