소개
If there are problems with the camera’s flash, the camera light may need to be replaced. If you are not sure if you need to replace the camera light, take a look at our camera flash troubleshooting page first.
필요한 것
Slide the battery door open with a finger or thumb and release it so the door opens.
Remove four 2mm Phillips #000 screws.
Remove two black 3mm Phillips #000 screws.
Remove one 4mm Phillips #000 screws.
Remove two silver 3mm Phillips #000 screws.
거의 끝나갑니다!
결론
