주요 콘텐츠로 건너뛰기
Nikon Coolpix S4000 Lense Casing Replacement
필요한 것
  1. Nikon Coolpix S4000 Lense Casing Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Nikon Coolpix S4000 Lense Casing Replacement: 2 단계, 이미지 1/1
    • Push the orange tab back and the battery will pop out.
  3. Nikon Coolpix S4000 Lense Casing Replacement, Casing: 3 단계, 이미지 1/3 Nikon Coolpix S4000 Lense Casing Replacement, Casing: 3 단계, 이미지 2/3 Nikon Coolpix S4000 Lense Casing Replacement, Casing: 3 단계, 이미지 3/3
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Nikon Coolpix S4000 Lense Casing Replacement: 4 단계, 이미지 1/2 Nikon Coolpix S4000 Lense Casing Replacement: 4 단계, 이미지 2/2
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Nikon Coolpix S4000 Lense Casing Replacement: 5 단계, 이미지 1/3 Nikon Coolpix S4000 Lense Casing Replacement: 5 단계, 이미지 2/3 Nikon Coolpix S4000 Lense Casing Replacement: 5 단계, 이미지 3/3
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Nikon Coolpix S4000 Lense Casing Replacement, Lens Casing: 6 단계, 이미지 1/1
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Nikon Coolpix S4000 Lense Casing Replacement: 7 단계, 이미지 1/2 Nikon Coolpix S4000 Lense Casing Replacement: 7 단계, 이미지 2/2
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
결론
Matina Newsom
회원 가입일: 02/21/18
779 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 274
