소개
This casing not only protects the lense, but acts as the decorative silver plastic running around the side of the camera, and holds the buttons on top.
It may need replacement in the event a button is broken, or any of the casing is cracked while using the camera.
필요한 것
Slide the battery door open with a finger or thumb and release it so the door opens.
Remove four 2mm Phillips #000 screws.
Remove two black 3mm Phillips #000 screws.
Remove one 4mm Phillips #000 screws.
Remove two silver 3mm Phillips #000 screws.
거의 끝나갑니다!
결론
