소개
If you need to replace the video record, playback, or camera mode buttons, then you must follow these steps to replace the metal plate with the mounted wiring.
필요한 것
Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
There are 2 on each side, and 4 on the bottom.
Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
다른 한 분이 해당 안내서를 완성하였습니다.
