주요 콘텐츠로 건너뛰기
Nikon Coolpix S4100 Functional Button Plate Replacement
필요한 것
  1. Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: 1 단계, 이미지 1/3 Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: 1 단계, 이미지 2/3 Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: 1 단계, 이미지 3/3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 Functional Button Plate Replacement: 2 단계, 이미지 1/1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 Functional Button Plate Replacement: 3 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 Functional Button Plate Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S4100 Functional Button Plate Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S4100 Functional Button Plate Replacement: 4 단계, 이미지 3/3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 Functional Button Plate Replacement: 5 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 Functional Button Plate Replacement: 6 단계, 이미지 1/2 Nikon Coolpix S4100 Functional Button Plate Replacement: 6 단계, 이미지 2/2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 Functional Button Plate Replacement: 7 단계, 이미지 1/3 Nikon Coolpix S4100 Functional Button Plate Replacement: 7 단계, 이미지 2/3 Nikon Coolpix S4100 Functional Button Plate Replacement: 7 단계, 이미지 3/3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 Functional Button Plate Replacement: 8 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 Functional Button Plate Replacement: 9 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 Functional Button Plate Replacement: 10 단계, 이미지 1/1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 Functional Button Plate Replacement: 11 단계, 이미지 1/1
    • Remove the top shell casing.
  12. Nikon Coolpix S4100 Functional Button Plate Replacement, Functional Button Plate: 12 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
  13. Nikon Coolpix S4100 Functional Button Plate Replacement: 13 단계, 이미지 1/1
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
  14. Nikon Coolpix S4100 Functional Button Plate Replacement: 14 단계, 이미지 1/1
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Willis
회원 가입일: 09/22/15
586 평판
안내서 4개 작성하였습니다
Baylor, Team 4-2, Williams Fall 2015 Baylor, Team 4-2, Williams Fall 2015 회원
BU-WILLIAMS-F15S4G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 357
