주요 콘텐츠로 건너뛰기
Nikon Coolpix S4100 LCD Screen Replacement
필요한 것
  1. Nikon Coolpix S4100 LCD Screen Replacement, External Casing: 1 단계, 이미지 1/3 Nikon Coolpix S4100 LCD Screen Replacement, External Casing: 1 단계, 이미지 2/3 Nikon Coolpix S4100 LCD Screen Replacement, External Casing: 1 단계, 이미지 3/3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 LCD Screen Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S4100 LCD Screen Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S4100 LCD Screen Replacement: 4 단계, 이미지 3/3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 LCD Screen Replacement: 6 단계, 이미지 1/2 Nikon Coolpix S4100 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 LCD Screen Replacement: 7 단계, 이미지 1/3 Nikon Coolpix S4100 LCD Screen Replacement: 7 단계, 이미지 2/3 Nikon Coolpix S4100 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 LCD Screen Replacement: 8 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 LCD Screen Replacement: 9 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 LCD Screen Replacement: 10 단계, 이미지 1/1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 LCD Screen Replacement: 11 단계, 이미지 1/1
    • Remove the top shell casing.
  12. Nikon Coolpix S4100 LCD Screen Replacement, Functional Button Plate: 12 단계, 이미지 1/1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
  13. Nikon Coolpix S4100 LCD Screen Replacement: 13 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
  14. Nikon Coolpix S4100 LCD Screen Replacement: 14 단계, 이미지 1/1
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
  15. Nikon Coolpix S4100 LCD Screen Replacement, LCD Screen: 15 단계, 이미지 1/2 Nikon Coolpix S4100 LCD Screen Replacement, LCD Screen: 15 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using precision tweezers, gently remove the ribbon cable running from LCD to the bottom side of the motherboard.
  16. Nikon Coolpix S4100 LCD Screen Replacement: 16 단계, 이미지 1/2 Nikon Coolpix S4100 LCD Screen Replacement: 16 단계, 이미지 2/2
    • Using precision tweezers, gently lift up on the black strip of the ZIF Connector securing the cable from the LCD to the motherboard.
    • Then, gently remove the wire by pulling the base of the ribbon cable towards the LCD screen.
    • Do not poke or destroy the cable itself. Be careful to only grab the black fold in the tweezers.
    • The black strip will fold back to reveal the cable, but remain attached to the motherboard.
  17. Nikon Coolpix S4100 LCD Screen Replacement: 17 단계, 이미지 1/2 Nikon Coolpix S4100 LCD Screen Replacement: 17 단계, 이미지 2/2
    • Remove the LCD screen from the metal mount.
결론
Matthew Willis
회원 가입일: 09/22/15
598 평판
안내서 4개 작성하였습니다
Baylor, Team 4-2, Williams Fall 2015 Baylor, Team 4-2, Williams Fall 2015 회원
BU-WILLIAMS-F15S4G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 21
전체 시간: 809
