이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
Remove this screw using a Phillips #00 screwdriver.
Rotate the camera to find the side panel with the lanyard attachment.
Detach the side panel by the lifting bottom corner slightly with the spudger.
Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Remove the five screws on the metal plate.
Remove the screw at the bottom of the camera.
Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
Lift the white flap with the spudger to release the ribbon.
Remove the back metal plate.
Lift the two ribbons with the spudger to disconnect the lens and pull it out.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
question: any source for replacement lens block ? can't find any on the internet
question: any source for lens block ? I can't find any on the internet
