주요 콘텐츠로 건너뛰기
Nikon Coolpix S51c Motherboard Replacement
필요한 것
  1. Nikon Coolpix S51c Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 Nikon Coolpix S51c Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Nikon Coolpix S51c Motherboard Replacement: 2 단계, 이미지 1/1
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Motherboard Replacement: 3 단계, 이미지 1/1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Motherboard Replacement: 5 단계, 이미지 1/1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  6. Nikon Coolpix S51c Motherboard Replacement, Lens: 6 단계, 이미지 1/3 Nikon Coolpix S51c Motherboard Replacement, Lens: 6 단계, 이미지 2/3 Nikon Coolpix S51c Motherboard Replacement, Lens: 6 단계, 이미지 3/3
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Nikon Coolpix S51c Motherboard Replacement: 7 단계, 이미지 1/2 Nikon Coolpix S51c Motherboard Replacement: 7 단계, 이미지 2/2
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Nikon Coolpix S51c Motherboard Replacement: 8 단계, 이미지 1/3 Nikon Coolpix S51c Motherboard Replacement: 8 단계, 이미지 2/3 Nikon Coolpix S51c Motherboard Replacement: 8 단계, 이미지 3/3
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
  9. Nikon Coolpix S51c Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Nikon Coolpix S51c Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Lift two flaps with the spudger on the top of the motherboard to release ribbons.
  10. Nikon Coolpix S51c Motherboard Replacement: 10 단계, 이미지 1/2 Nikon Coolpix S51c Motherboard Replacement: 10 단계, 이미지 2/2
    • lift motherboard from the top to remove it from the camera.
결론
Ryan
회원 가입일: 04/12/11
155 평판
안내서 6개 작성하였습니다
Cal Poly, Team 18-24, Garner Spring 2011 Cal Poly, Team 18-24, Garner Spring 2011 회원
CPSU-GARNER-S11S18G24
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 8
전체 시간: 1,805
