주요 콘텐츠로 건너뛰기
Nikon Coolpix S5200 LCD Screen Replacement
필요한 것
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: 7 단계, 이미지 1/2 Nikon Coolpix S5200 LCD Screen Replacement: 7 단계, 이미지 2/2
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
결론
Andy Powers
회원 가입일: 09/22/15
391 평판
안내서 3개 작성하였습니다
University of Alabama, Team 1-2, Sydow campbell Fall 2015 University of Alabama, Team 1-2, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 23
전체 시간: 1,053
