주요 콘텐츠로 건너뛰기
Nikon Coolpix S5200 Plastic Back Cover Replacement
필요한 것
  1. Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: 1 단계, 이미지 1/3 Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: 1 단계, 이미지 2/3 Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: 1 단계, 이미지 3/3
    • Locate the left side of the camera
  2. Nikon Coolpix S5200 Plastic Back Cover Replacement: 2 단계, 이미지 1/1
    • Remove the two 0.1 mm screws using a Phillips Head screwdriver in order to properly open the camera
  3. Nikon Coolpix S5200 Plastic Back Cover Replacement: 3 단계, 이미지 1/1
    • Carefully lift the plastic back cover away from the camera
    • Remove the plastic cover from the camera
  4. Nikon Coolpix S5200 Plastic Back Cover Replacement: 4 단계, 이미지 1/2 Nikon Coolpix S5200 Plastic Back Cover Replacement: 4 단계, 이미지 2/2
    • Carefully push the rubber button cover up and out of the plastic cover
    • The plastic cover has been properly removed and is ready to be replaced
결론
Andy Powers
회원 가입일: 09/22/15
391 평판
안내서 3개 작성하였습니다
University of Alabama, Team 1-2, Sydow campbell Fall 2015 University of Alabama, Team 1-2, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 338
