주요 콘텐츠로 건너뛰기
Nikon Coolpix S5300 Button Panel Replacement
필요한 것
  1. Nikon Coolpix S5300 Button Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300 Button Panel Replacement: 2 단계, 이미지 1/1
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300 Button Panel Replacement, Outer Casing: 3 단계, 이미지 1/3 Nikon Coolpix S5300 Button Panel Replacement, Outer Casing: 3 단계, 이미지 2/3 Nikon Coolpix S5300 Button Panel Replacement, Outer Casing: 3 단계, 이미지 3/3
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300 Button Panel Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S5300 Button Panel Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S5300 Button Panel Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300 Button Panel Replacement: 5 단계, 이미지 1/3 Nikon Coolpix S5300 Button Panel Replacement: 5 단계, 이미지 2/3 Nikon Coolpix S5300 Button Panel Replacement: 5 단계, 이미지 3/3
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300 Button Panel Replacement: 6 단계, 이미지 1/2 Nikon Coolpix S5300 Button Panel Replacement: 6 단계, 이미지 2/2
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300 Button Panel Replacement: 7 단계, 이미지 1/2 Nikon Coolpix S5300 Button Panel Replacement: 7 단계, 이미지 2/2
    • Carefully remove the top button casing by pulling it away from main camera.
  8. Nikon Coolpix S5300 Button Panel Replacement, Button Panel: 8 단계, 이미지 1/1
    • Remove the 2 screws on the silver plate
    • Gently lift the screen and silver plate away from the internal components.
    • Do not separate the plate and screen from the camera
  9. Nikon Coolpix S5300 Button Panel Replacement: 9 단계, 이미지 1/2 Nikon Coolpix S5300 Button Panel Replacement: 9 단계, 이미지 2/2
    • Carefully move the button panel away from the silver plate.
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
    • Safely pull the ribbon cable out and then remove the button panel.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
결론
Waleed Chakir
회원 가입일: 03/04/16
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-1, Bhusal Spring 2016 UMass Dartmouth, Team 6-1, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 222
