소개
This guide allows one to remove the lens assembly unit from the camera. Thus is can then be replaced by a new one.
필요한 것
Turn the camera upside down and locate the battery compartment.
Slide the compartment open following the direction of the arrow.
Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
Using the same screwdriver, remove the 2 screws on the side of the camera.
Remove the 2 screws from the other side of the camera.
Remove the 2 screws on the silver plate
Gently lift the screen and silver plate away from the internal components.
Carefully remove the screen away from the silver plate.
Carefully fold the screen over exposing the latch for the ribbon cable.
Using the phillips head screwdriver, remove the three 0.1mm screws on the metal plate.
Carefully remove metal plate from the camera.
To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
Carefully push the lens towards you until it is almost removed from the chamber.
Remove the lens assembly from the camera.
다른 한 분이 해당 안내서를 완성하였습니다.
