주요 콘텐츠로 건너뛰기
Nikon Coolpix S630 Back Cover Replacement
필요한 것
  1. Nikon Coolpix S630 Back Cover Replacement, Battery Compartment: 1 단계, 이미지 1/1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Back Cover Replacement, Battery: 2 단계, 이미지 1/1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Back Cover Replacement, Memory Card: 3 단계, 이미지 1/1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: 4 단계, 이미지 1/3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: 4 단계, 이미지 2/3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: 4 단계, 이미지 3/3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Back Cover Replacement: 5 단계, 이미지 1/1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: 6 단계, 이미지 1/2 Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: 6 단계, 이미지 2/2
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
결론
Anna Katrina
회원 가입일: 04/18/13
28 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013 회원
CPSU-JOHANN-S13S8G56
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 468
