주요 콘텐츠로 건너뛰기
Nikon Coolpix S630 Shutter Button Replacement
필요한 것
  1. Nikon Coolpix S630 Shutter Button Replacement, Battery Compartment: 1 단계, 이미지 1/1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Shutter Button Replacement, Battery: 2 단계, 이미지 1/1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Shutter Button Replacement, Memory Card: 3 단계, 이미지 1/1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Shutter Button Replacement, Front Cover: 4 단계, 이미지 1/1
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  5. Nikon Coolpix S630 Shutter Button Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  6. Nikon Coolpix S630 Shutter Button Replacement, Shutter Button: 6 단계, 이미지 1/1
    • Place the front cover facing down so that you can easily see the shutter button.
  7. Nikon Coolpix S630 Shutter Button Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, gently slide the shutter button out.
    • Be very gentle because you can damage the piece.
결론
Aulivia Bounchaleun
회원 가입일: 04/19/13
10 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013 회원
CPSU-JOHANN-S13S8G56
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 37
전체 시간: 2,190
