주요 콘텐츠로 건너뛰기
Nikon Coolpix S6300 Display Replacement
필요한 것
  1. Nikon Coolpix S6300 Display Replacement, Battery: 1 단계, 이미지 1/1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Display Replacement: 2 단계, 이미지 1/1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Display Replacement, Buttons: 3 단계, 이미지 1/3 Nikon Coolpix S6300 Display Replacement, Buttons: 3 단계, 이미지 2/3 Nikon Coolpix S6300 Display Replacement, Buttons: 3 단계, 이미지 3/3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Display Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S6300 Display Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S6300 Display Replacement: 4 단계, 이미지 3/3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Display Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Display Replacement: 6 단계, 이미지 1/1
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Display Replacement: 7 단계, 이미지 1/1
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Display Replacement, Display: 8 단계, 이미지 1/1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
결론
Hung
회원 가입일: 09/01/15
383 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Remmell Fall 2015 USF Tampa, Team 1-2, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G2
5 회원들
안내서 10개 작성하였습니다
댓글 2개
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - 답글
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 22
전체 시간: 1,492
