주요 콘텐츠로 건너뛰기
Nikon Coolpix S6300 Polarizing Lens Replacement
필요한 것
  1. Nikon Coolpix S6300 Polarizing Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Polarizing Lens Replacement: 2 단계, 이미지 1/1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Polarizing Lens Replacement, Buttons: 3 단계, 이미지 1/3 Nikon Coolpix S6300 Polarizing Lens Replacement, Buttons: 3 단계, 이미지 2/3 Nikon Coolpix S6300 Polarizing Lens Replacement, Buttons: 3 단계, 이미지 3/3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Polarizing Lens Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S6300 Polarizing Lens Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S6300 Polarizing Lens Replacement: 4 단계, 이미지 3/3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Polarizing Lens Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Polarizing Lens Replacement: 6 단계, 이미지 1/1
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Polarizing Lens Replacement: 7 단계, 이미지 1/1
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Polarizing Lens Replacement, Display: 8 단계, 이미지 1/1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
  9. Nikon Coolpix S6300 Polarizing Lens Replacement, Polarizing Lens: 9 단계, 이미지 1/3 Nikon Coolpix S6300 Polarizing Lens Replacement, Polarizing Lens: 9 단계, 이미지 2/3 Nikon Coolpix S6300 Polarizing Lens Replacement, Polarizing Lens: 9 단계, 이미지 3/3
    • Remove the four PH00 2.5 mm screws around the edges of the display plate.
    • Remove the three PH00 2 mm screws from the sides of the buttons plate and the 2.5 mm screw from the center of the buttons plate.
    • Lift the buttons plate out of the camera with the plastic tool.
    • Lift the display plate out of the camera with the plastic tool.
  10. Nikon Coolpix S6300 Polarizing Lens Replacement: 10 단계, 이미지 1/3 Nikon Coolpix S6300 Polarizing Lens Replacement: 10 단계, 이미지 2/3 Nikon Coolpix S6300 Polarizing Lens Replacement: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the plastic opening tool to gently flip the white folders at the end of the ribbon cables.
    • Use this tweezers to gently pull the cables out of the holders.
    • Lift the lens apparatus out of the rest of the camera by pushing the front of lens up from the bottom.
  11. Nikon Coolpix S6300 Polarizing Lens Replacement: 11 단계, 이미지 1/2 Nikon Coolpix S6300 Polarizing Lens Replacement: 11 단계, 이미지 2/2
    • Use the plastic opening tool to flip the two white clips holding the ribbon cables.
    • Use tweezers to pull the cables from clamps.
    • Use the PH00 screwdriver to remove the three 2 mm screws around the first lens area.
  12. Nikon Coolpix S6300 Polarizing Lens Replacement: 12 단계, 이미지 1/2 Nikon Coolpix S6300 Polarizing Lens Replacement: 12 단계, 이미지 2/2
    • Lift the first lens from the rest of the lens apparatus.
    • Use thin tweezers to left and remove the polarizing lens from the apparatus.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Lynch
회원 가입일: 08/31/15
396 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-2, Remmell Fall 2015 USF Tampa, Team 1-2, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 1,013
