주요 콘텐츠로 건너뛰기
Nikon Coolpix S7000 Shutter Button Replacement
필요한 것
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: 1 단계, 이미지 1/2 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: 1 단계, 이미지 2/2
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: 2 단계, 이미지 1/2 Nikon Coolpix S7000 Shutter Button Replacement: 2 단계, 이미지 2/2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: 3 단계, 이미지 1/2 Nikon Coolpix S7000 Shutter Button Replacement: 3 단계, 이미지 2/2
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S7000 Shutter Button Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S7000 Shutter Button Replacement: 4 단계, 이미지 3/3
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
결론
Nicholas Leon-Schetina
회원 가입일: 02/24/17
113 평판
안내서 1개 작성함
USF Tampa, Team S2-G3, Lacy Spring 2017 USF Tampa, Team S2-G3, Lacy Spring 2017 회원
USFT-LACY-S17S2G3
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
shutter keeps trying to open. clicks slighly and does not open
Beatrix - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 715
