주요 콘텐츠로 건너뛰기
Nikon Coolpix S7000 Sticky Button Replacement
필요한 것
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: 2 단계, 이미지 1/3 Nikon Coolpix S7000 Sticky Button Replacement: 2 단계, 이미지 2/3 Nikon Coolpix S7000 Sticky Button Replacement: 2 단계, 이미지 3/3
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: 3 단계, 이미지 1/2 Nikon Coolpix S7000 Sticky Button Replacement: 3 단계, 이미지 2/2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S7000 Sticky Button Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S7000 Sticky Button Replacement: 4 단계, 이미지 3/3
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: 5 단계, 이미지 1/1
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: 6 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shannon Beane
회원 가입일: 01/10/17
324 평판
안내서 2개 작성하였습니다
USF Tampa, Team S2-G3, Lacy Spring 2017 USF Tampa, Team S2-G3, Lacy Spring 2017 회원
USFT-LACY-S17S2G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 34
전체 시간: 2,337
