주요 콘텐츠로 건너뛰기
Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide
필요한 것
  1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: 1 단계, 이미지 2개 중 1개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: 1 단계, 이미지 2개 중 2개
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 2 단계, 이미지 2개 중 1개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 2 단계, 이미지 2개 중 2개
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Motherboard: 3 단계, 이미지 1개 중 1개
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 4 단계, 이미지 1개 중 1개
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 5 단계, 이미지 1개 중 1개
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 6 단계, 이미지 3개 중 1개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 6 단계, 이미지 3개 중 2개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 6 단계, 이미지 3개 중 3개
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 7 단계, 이미지 2개 중 1개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 7 단계, 이미지 2개 중 2개
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 8 단계, 이미지 2개 중 1개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 8 단계, 이미지 2개 중 2개
    • Pull the motherboard off of the main body of the camera.
  9. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: 9 단계, 이미지 3개 중 1개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: 9 단계, 이미지 3개 중 2개 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: 9 단계, 이미지 3개 중 3개
    • Use a plastic opening tool of your choice to loosen and pry up the zoom unit/shutter component.
    • Use your hands to manually lift the zoom unit/shutter component up and out of the main body of the camera.
결론
작성자
2다른 기여자 명과 함께
Erik Knapton
회원 가입일: 01/30/18
222 평판
안내서 2개를 작성함
Baylor, Team S2-G6, Johnson Spring 2018 Baylor, Team S2-G6, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G6
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 398
