주요 콘텐츠로 건너뛰기
Nikon Coolpix S8200 CCD Lens Replacement
필요한 것
  1. Nikon Coolpix S8200 CCD Lens Replacement, CCD Lens: 1 단계, 이미지 1/1
    • First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
    • Be careful not to remove any extra screws.
  2. Nikon Coolpix S8200 CCD Lens Replacement: 2 단계, 이미지 1/1
    • Once the back is removed, Do Not remove the ribbon cables shown in the within the red circles on the image.
  3. Nikon Coolpix S8200 CCD Lens Replacement: 3 단계, 이미지 1/1
    • Unscrew the two screws around the silver disk-like part indicated by the red circles on the image and then remove them.
    • Next gently remove the black strap indicated by the yellow circle on the image.
    • The black strap can easily snap back on for reassembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nelson Antiposti
회원 가입일: 03/25/15
499 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-3, Kish Spring 2015 UMass Dartmouth, Team 5-3, Kish Spring 2015 회원
UMASSD-KISH-S15S5G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 17
전체 시간: 2,158
