소개
If you have continually received a lens error on your camera and restarting it doesn't help, then you need to replace the CCD lens. This guide walks you through the steps necessary to replace the CCD lens on the Nikon Coolpix S8200.
필요한 것
First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
다른 한 분이 해당 안내서를 완성하였습니다.
