주요 콘텐츠로 건너뛰기
Nikon Coolpix S9050 Menu Wheel and OK Button Replacement
필요한 것
  1. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: 1 단계, 이미지 1/3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: 1 단계, 이미지 2/3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: 1 단계, 이미지 3/3
    • Remove the screws. There are two on each side, and four on the bottom. The black screws are 3.2 mm Phillips #000. The silver screws are also 3.2 mm Phillips #000.
  2. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: 2 단계, 이미지 1/1
    • Remove the screen housing and trim piece.
  3. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: 3 단계, 이미지 1/3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: 3 단계, 이미지 2/3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: 3 단계, 이미지 3/3
    • Press down and pull the Menu Wheel/OK Button panel towards the screen. This will release the panel from the slots.
  4. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: 4 단계, 이미지 3/3
    • Lift up on the black plastic tab(zero insertion force connector-ZIF) and gently pull the panel out to detach the ribbon cable from the camera body.
결론
Catrionna Bruce
회원 가입일: 11/01/18
205 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G3, Harley Fall 2018 IUPUI, Team S3-G3, Harley Fall 2018 회원
IUPUI-HARLEY-F18S3G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 467
