주요 콘텐츠로 건너뛰기
Nikon Coolpix S9050 Motherboard Replacement
필요한 것
  1. Nikon Coolpix S9050 Motherboard Replacement, Menu Wheel and OK Button: 1 단계, 이미지 1/3 Nikon Coolpix S9050 Motherboard Replacement, Menu Wheel and OK Button: 1 단계, 이미지 2/3 Nikon Coolpix S9050 Motherboard Replacement, Menu Wheel and OK Button: 1 단계, 이미지 3/3
    • Remove the screws. There are two on each side, and four on the bottom. The black screws are 3.2 mm Phillips #000. The silver screws are also 3.2 mm Phillips #000.
  2. Nikon Coolpix S9050 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the screen housing and trim piece.
  3. Nikon Coolpix S9050 Motherboard Replacement: 3 단계, 이미지 1/3 Nikon Coolpix S9050 Motherboard Replacement: 3 단계, 이미지 2/3 Nikon Coolpix S9050 Motherboard Replacement: 3 단계, 이미지 3/3
    • Press down and pull the Menu Wheel/OK Button panel towards the screen. This will release the panel from the slots.
  4. Nikon Coolpix S9050 Motherboard Replacement: 4 단계, 이미지 1/3 Nikon Coolpix S9050 Motherboard Replacement: 4 단계, 이미지 2/3 Nikon Coolpix S9050 Motherboard Replacement: 4 단계, 이미지 3/3
    • Lift up on the black plastic tab(zero insertion force connector-ZIF) and gently pull the panel out to detach the ribbon cable from the camera body.
  5. Nikon Coolpix S9050 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 Nikon Coolpix S9050 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 Nikon Coolpix S9050 Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Remove the screws surrounding the screen using the Phillips #000 screwdriver.
    • Use the spudger to detach the display ribbon cable.
  6. Nikon Coolpix S9050 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the silver 3.2 mm Phillips #000 screws surrounding the metal panel.
  7. Nikon Coolpix S9050 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the silver 3.2 mm Phillips #000 screws from the side panel.
  8. Nikon Coolpix S9050 Motherboard Replacement: 8 단계, 이미지 1/3 Nikon Coolpix S9050 Motherboard Replacement: 8 단계, 이미지 2/3 Nikon Coolpix S9050 Motherboard Replacement: 8 단계, 이미지 3/3
    • After removing metal panel, use the spudger to detach the the 3 ribbon wires attached to the motherboard. Now, remove the silver 3.2 mm Phillips #000 screws holding the motherboard in place. Lastly, lift the board from the top of the camera and pull board upwards, pulling out the AV port with it.
결론
Kyle Gildner
회원 가입일: 11/05/19
193 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G5, Stella Fall 2019 IUPUI, Team S1-G5, Stella Fall 2019 회원
IUPUI-STELLA-F19S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 259
