주요 콘텐츠로 건너뛰기
Nikon Coolpix S9700 Flash Housing Replacement
필요한 것
  1. Nikon Coolpix S9700 Flash Housing Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Flash Housing Replacement: 2 단계, 이미지 3개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement: 2 단계, 이미지 3개 중 2개 Nikon Coolpix S9700 Flash Housing Replacement: 2 단계, 이미지 3개 중 3개
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Flash Housing Replacement: 3 단계, 이미지 3개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement: 3 단계, 이미지 3개 중 2개 Nikon Coolpix S9700 Flash Housing Replacement: 3 단계, 이미지 3개 중 3개
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Flash Housing Replacement: 4 단계, 이미지 2개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement: 4 단계, 이미지 2개 중 2개
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: 5 단계, 이미지 3개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: 5 단계, 이미지 3개 중 2개 Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: 5 단계, 이미지 3개 중 3개
    • Place your fingernail or a plastic opening tool in the space between the camera housing and the flash housing.
    • Carefully pry up on the flash housing. It will pop up automatically.
  6. Nikon Coolpix S9700 Flash Housing Replacement: 6 단계, 이미지 3개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement: 6 단계, 이미지 3개 중 2개 Nikon Coolpix S9700 Flash Housing Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two 4-mm J000 screws positioned at the bottom of the flash housing.
    • The housing will now be hanging only by the ribbon supplying power.
  7. Nikon Coolpix S9700 Flash Housing Replacement: 7 단계, 이미지 3개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement: 7 단계, 이미지 3개 중 2개 Nikon Coolpix S9700 Flash Housing Replacement: 7 단계, 이미지 3개 중 3개
    • Using your fingers or plastic opening tool, remove the back half from the front half of the flash housing. The front half will stay on.
    • Sudden or large force can rip the flash power supply off.
  8. Nikon Coolpix S9700 Flash Housing Replacement: 8 단계, 이미지 3개 중 1개 Nikon Coolpix S9700 Flash Housing Replacement: 8 단계, 이미지 3개 중 2개 Nikon Coolpix S9700 Flash Housing Replacement: 8 단계, 이미지 3개 중 3개
    • Place a plastic opening tool on the clear lens of the flash.
    • Gently push on the lens to remove the front half of the flash housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Matt Staubus
회원 가입일: 10/05/16
849 평판
안내서 5개를 작성함
USF Tampa, Team 9-5, Lacy Fall 2016 USF Tampa, Team 9-5, Lacy Fall 2016 회원
USFT-LACY-F16S9G5
4 회원들
안내서 10개를 작성함
4가이드 댓글
I dropped my coopix and cannot get it back in. Is there a way to replace the flash?
Charles Cezeaux - 답글
Dropped my Nikon Coolpix S9700 and broke the flash. It will not go back inside camera. Can it be replaced or repaired?
Does anyone know if it can be replaced or repaired?
I have done this to my camera. Cannot find replacement for flash. Can i use the camera as is?
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 1,333
