주요 콘텐츠로 건너뛰기
Nikon D3100 Lens Mounting Ring Reseating/Replacement
필요한 것
  1. Nikon D3100 Lens Mounting Ring Reseating/Replacement, Lens Mounting Ring: 1 단계, 이미지 1/1
    • Remove the 6 Phillips screws on the front of the lens mounting ring.
  2. Nikon D3100 Lens Mounting Ring Reseating/Replacement: 2 단계, 이미지 1/1
    • Carefully lift the mounting ring straight up.
    • Three unfastened metal plates lie under the lens mounting ring, be very careful lifting it up as to not disturb them.
  3. Nikon D3100 Lens Mounting Ring Reseating/Replacement: 3 단계, 이미지 1/2 Nikon D3100 Lens Mounting Ring Reseating/Replacement: 3 단계, 이미지 2/2
    • Reseat or replace the lens mounting ring and reassemble.
    • The locating pin on the right of the camera will help place the mounting ring properly.
    • The small metal plates marked in the image are not fastened and may displace if the camera if tipped or bumped. Be sure these are properly in place before reassembly.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Taylor
회원 가입일: 01/30/15
1,165 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G6
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 22
전체 시간: 4,101
