소개
If you can see black rings around the outside of the image preview, the lens may not be mounted correctly or the lens mounting ring has worn down and no longer holds the lens in position. If you have this problem use this guide to reseat or replace the lens mounting ring.
필요한 것
거의 끝나갑니다!
결론
다른 9명이 해당 안내서를 완성하였습니다.
