주요 콘텐츠로 건너뛰기
Nikon D3200 Memory Card Replacement
  1. Nikon D3200 Memory Card Replacement, Memory Card: 1 단계, 이미지 1/1
    • Locate the memory card compartment on the right side of the LCD screen.
  2. Nikon D3200 Memory Card Replacement: 2 단계, 이미지 1/3 Nikon D3200 Memory Card Replacement: 2 단계, 이미지 2/3 Nikon D3200 Memory Card Replacement: 2 단계, 이미지 3/3
    • Gently press and slide the grooved compartment door to the left.
    • Let go of the compartment door and it will swing open.
    • Insert the memory card imitating the diagram pictured outside the compartment door.
    • Make sure to push down once the memory card is inserted to lock it in place.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Irene Huang
회원 가입일: 09/08/14
681 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 1-3, Bruce Fall 2014 CSU Fullerton, Team 1-3, Bruce Fall 2014 회원
CSUF-BRUCE-F14S1G3
6 회원들
안내서 4개 작성하였습니다
댓글 한 개
Hello is this about replacing the memory card compartment or just the memory card? Apparently the memory card compartment is not maintining the memory, it’s not keeping it in the memor slot keeps popping back up. How do I fix this? Can I replace the housing?
Joseph Antonio - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 26
전체 시간: 4,495
