주요 콘텐츠로 건너뛰기
Nikon D40 Flash Pin Replacement
필요한 것
  1. Nikon D40 Flash Pin Replacement, Flash Pin: 1 단계, 이미지 1/1
    • Turn off the camera and remove the battery.
  2. Nikon D40 Flash Pin Replacement: 2 단계, 이미지 1/1
    • Pry the flash open using the plastic opening tool.
  3. Nikon D40 Flash Pin Replacement: 3 단계, 이미지 1/1
    • Remove the two Phillips #0 3.0 mm screws from the front of the flash compartment using the small Phillips Head screwdriver.
  4. Nikon D40 Flash Pin Replacement: 4 단계, 이미지 1/2 Nikon D40 Flash Pin Replacement: 4 단계, 이미지 2/2
    • Pry off the back plastic of the flash compartment using the plastic opening tool.
    • When it is time to reassemble the flash module, a certain amount of force and precise alignment will be required.
  5. Nikon D40 Flash Pin Replacement: 5 단계, 이미지 1/2 Nikon D40 Flash Pin Replacement: 5 단계, 이미지 2/2
    • On the left of the camera you will see a metal spring.
    • Unscrew the Phillips #0 3.0 mm screw holding the spring in place, using the small Phillips Head screwdriver.
  6. Nikon D40 Flash Pin Replacement: 6 단계, 이미지 1/1
    • Remove metal spring and replace with new spring.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Lindsey Chase
회원 가입일: 01/21/14
227 평판
안내서 1개 작성함
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 회원
CPSU-MANESS-W14S6G19
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 3,767
