소개
LCD screens are known to shatter when dropped. In this guide you will replace the LCD screen that is on the inside of the camera.
  1. Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera. Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. While pulling the bottom down, remove the back of the camera.
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  6. Remove the six 3.0 mm Philips #0 screws on the inside of the back panel which contains the LCD screen.
    • Remove the six 3.0 mm Philips #0 screws on the inside of the back panel which contains the LCD screen.
  7. Detach the ribbon cables on the LCD casing.
    • Detach the ribbon cables on the LCD casing.
  8. Remove the metal casing containing the LCD screen using the plastic opening tool.
    • Remove the metal casing containing the LCD screen using the plastic opening tool.
    • Be sure to look at the picture to make sure you are removing the correct piece of metal. There should be no glue holding the correct piece to the frame.
  9. You should now be able to remove the LCD screen. Replace it with a new screen.
    • You should now be able to remove the LCD screen. Replace it with a new screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Gerik Kubiak
회원 가입일: 2014년 01월 21일
300 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 회원
CPSU-MANESS-W14S6G19
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 29
전체 시간: 4,333
