소개
The mainboard controls all of the software on the Nikon D40. A faulty mainboard can cause problems that will require a new board. This guide will show you how to replace the camera's mainboard.
필요한 것
Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
Worth mentioning, the top circled screw was a 6mm on my camera. The other 3 were 3mm.
Mark Brown - 답글
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
