주요 콘텐츠로 건너뛰기
Nikon D40 Mainboard Replacement
필요한 것
  1. Nikon D40 Mainboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Mainboard Replacement: 2 단계, 이미지 1/2 Nikon D40 Mainboard Replacement: 2 단계, 이미지 2/2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Mainboard Replacement: 3 단계, 이미지 1/1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
    Worth mentioning, the top circled screw was a 6mm on my camera. The other 3 were 3mm.
    Mark Brown - 답글
  4. Nikon D40 Mainboard Replacement: 4 단계, 이미지 1/1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Mainboard Replacement, Mainboard: 5 단계, 이미지 1/2 Nikon D40 Mainboard Replacement, Mainboard: 5 단계, 이미지 2/2
    • Remove the solder connecting the red wire to the mainboard.
  6. Nikon D40 Mainboard Replacement: 6 단계, 이미지 1/1
    • Desolder the 4 smaller wires near the bottom of the mainboard.
  7. Nikon D40 Mainboard Replacement: 7 단계, 이미지 1/2 Nikon D40 Mainboard Replacement: 7 단계, 이미지 2/2
    • Use the plastic opening tool to release the ribbon cables attached to the mainboard.
  8. Nikon D40 Mainboard Replacement: 8 단계, 이미지 1/1
    • Remove the five 3.0mm Philips #1 screws holding the mainboard down.
  9. Nikon D40 Mainboard Replacement: 9 단계, 이미지 1/2 Nikon D40 Mainboard Replacement: 9 단계, 이미지 2/2
    • Lift the mainboard up to reveal the final connection.
    • Carefully detach the white cable from the board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Joe Leija
회원 가입일: 01/21/14
518 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 회원
CPSU-MANESS-W14S6G19
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
Joseph Ruskiewicz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 22
전체 시간: 4,243
