주요 콘텐츠로 건너뛰기
Nikon D40 Viewfinder Replacement
필요한 것
  1. Nikon D40 Viewfinder Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Viewfinder Replacement: 2 단계, 이미지 1/2 Nikon D40 Viewfinder Replacement: 2 단계, 이미지 2/2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Viewfinder Replacement: 3 단계, 이미지 1/1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 Viewfinder Replacement: 4 단계, 이미지 1/1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Viewfinder Replacement, Viewfinder: 5 단계, 이미지 1/1
    • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
    • Be careful not to pull too hard on the ribbon cables.
  6. Nikon D40 Viewfinder Replacement: 6 단계, 이미지 1/1
    • Slowly push the upper body up until you see the frame of the viewfinder
    • Be careful while pulling the top camera body.
  7. Nikon D40 Viewfinder Replacement: 7 단계, 이미지 1/1
    • Use a spudger to keep the upper body separate from the printed circuit board.
    • Wiggle the plastic eyepiece out of the frame. This may require some force.
  8. Nikon D40 Viewfinder Replacement: 8 단계, 이미지 1/1
    • Remove the viewfinder with the plastic opening tool.
    • Do not push too hard while using the opening tool.
  9. Nikon D40 Viewfinder Replacement: 9 단계, 이미지 1/1
    • The viewfinder has been removed!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Amy Chen
회원 가입일: 01/23/14
193 평판
안내서 1개 작성함
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 회원
CPSU-MANESS-W14S6G19
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 3,235
