주요 콘텐츠로 건너뛰기
Nikon D5000 Battery Door Replacement
  1. Nikon D5000 Battery Door Replacement, Battery Door: 1 단계, 이미지 1/2 Nikon D5000 Battery Door Replacement, Battery Door: 1 단계, 이미지 2/2
    • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
  2. Nikon D5000 Battery Door Replacement: 2 단계, 이미지 1/2 Nikon D5000 Battery Door Replacement: 2 단계, 이미지 2/2
    • Grip and hold the front end of the battery door at a 45-degree angle from the case.
    • Pop the battery door out by pulling the front tab up.
    • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jacob Rardin
회원 가입일: 04/14/14
1,390 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-28, Maness Spring 2014 Cal Poly, Team 13-28, Maness Spring 2014 회원
CPSU-MANESS-S14S13G28
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 73
전체 시간: 5,157
