주요 콘텐츠로 건너뛰기
Nikon D5100 Battery Door Replacement
필요한 것
  1. Nikon D5100 Battery Door Replacement, Battery Door: 1 단계, 이미지 1/3 Nikon D5100 Battery Door Replacement, Battery Door: 1 단계, 이미지 2/3 Nikon D5100 Battery Door Replacement, Battery Door: 1 단계, 이미지 3/3
    • Insert the battery into the battery compartment at the bottom of the camera.
  2. Nikon D5100 Battery Door Replacement: 2 단계, 이미지 1/3 Nikon D5100 Battery Door Replacement: 2 단계, 이미지 2/3 Nikon D5100 Battery Door Replacement: 2 단계, 이미지 3/3
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
  3. Nikon D5100 Battery Door Replacement: 3 단계, 이미지 1/3 Nikon D5100 Battery Door Replacement: 3 단계, 이미지 2/3 Nikon D5100 Battery Door Replacement: 3 단계, 이미지 3/3
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
  4. Nikon D5100 Battery Door Replacement: 4 단계, 이미지 1/1
    • The metal bar should be attached and tightly secured.
  5. Nikon D5100 Battery Door Replacement: 5 단계, 이미지 1/2 Nikon D5100 Battery Door Replacement: 5 단계, 이미지 2/2
    • Turn on the camera to check that the battery is properly secure.
결승점
Michelle Tran
회원 가입일: 02/24/15
101 평판
안내서 1개 작성함
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 회원
CPSU-GREEN-W15S23G1
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 32
전체 시간: 2,767
