주요 콘텐츠로 건너뛰기
Nikon D5100 Memory Card Replacement
  1. Nikon D5100 Memory Card Replacement, Memory Card: 1 단계, 이미지 1/3 Nikon D5100 Memory Card Replacement, Memory Card: 1 단계, 이미지 2/3 Nikon D5100 Memory Card Replacement, Memory Card: 1 단계, 이미지 3/3
    • Open the memory card compartment door, located to the right of the digital display, by using your thumb to push it in the direction of the arrow.
  2. Nikon D5100 Memory Card Replacement: 2 단계, 이미지 1/1
    • Eject the memory card by pressing it into its slot until you hear a soft "click."
  3. Nikon D5100 Memory Card Replacement: 3 단계, 이미지 1/1
    • Using thumb and forefinger, gently remove the SD card from its slot.
결론
Liz
회원 가입일: 04/25/14
1,311 평판
안내서 5개 작성하였습니다
Cal Poly, Team 10-54, Amido Spring 2014 Cal Poly, Team 10-54, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G54
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
isn't this procedure in the user manual?
Happy Fixer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 2,338
