소개
The rear panel protects the motherboard and other components inside the camera and houses controls like buttons and dials. This guide will teach you how to remove and replace the rear panel of your Nikon D5100.
필요한 것
Use your fingernail to gently peel back the black rubber thumb grip, attached to the chassis with a strong adhesive.
Use the Phillips #00 to remove the screw underneath the black rubber grip.
Carefully peel back the black rubber hand grip, which is attached to the chassis with a strong adhesive.
Use the Phillips #00 to remove two screws beneath the handgrip.
Warning: these two screws are made from a different material than most of the other ones. They're quite fragile and prone to the screw head wearing out. You don't want that to happen! Make sure you use a good quality screwdriver and apply enough pressure so that your screwdriver doesn't "slide" and damage the screw head.
Using a spudger, pry off the diopter adjustment dial cover and remove the screw underneath.
Next, using a Phillips #00 screwdriver, remove the three Phillips screws around the viewfinder.
Remove the silver 16-pin cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
At this point, the rear panel is fully separated from the main body of the camera.
다른 7명이 해당 안내서를 완성하였습니다.
