주요 콘텐츠로 건너뛰기
Nikon D5200 Battery Removal
  1. Nikon D5200 Battery Removal, Nikon D5200 Battery Removal: 1 단계, 이미지 1/1
    • Open the compartment door by sliding the release switch toward the tripod mount and pulling the door outwards.
  2. Nikon D5200 Battery Removal: 2 단계, 이미지 1/1
    • Press the yellow tab downwards to release the battery, and then hold the camera upright to allow the battery to slip out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexander Corn
회원 가입일: 08/26/15
1,282 평판
안내서 5개 작성하였습니다
USF Tampa, Team 3-1, Eyestone Fall 2015 USF Tampa, Team 3-1, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G1
4 회원들
안내서 5개 작성하였습니다
댓글 3개
Mine is stuck! It won't open at all
Anne - 답글
it woks thanks for advice
Willow Mccrone - 답글
Awesome, if the batery does not come off the camera, it may be blown, open the small black rubber tip on the side of the camera and pull the battery out by pulling with a metal stick in a hole the battery has.
Leo san - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 29
전체 시간: 6,768
