주요 콘텐츠로 건너뛰기
Nikon D610 Battery Replacement
필요한 것
  1. Nikon D610 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • First, power off the device.
  2. Nikon D610 Battery Replacement: 2 단계, 이미지 1/3 Nikon D610 Battery Replacement: 2 단계, 이미지 2/3 Nikon D610 Battery Replacement: 2 단계, 이미지 3/3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Battery Replacement: 3 단계, 이미지 1/2 Nikon D610 Battery Replacement: 3 단계, 이미지 2/2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
결론
Daniel Eagan
회원 가입일: 02/10/16
606 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-4, Lacy Spring 2016 USF Tampa, Team 4-4, Lacy Spring 2016 회원
USFT-LACY-S16S4G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
This is my kind of fixing )
Loic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 19
전체 시간: 1,473
