주요 콘텐츠로 건너뛰기
Nikon D610 Motherboard Replacement
필요한 것
  1. Nikon D610 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • First, power off the device.
  2. Nikon D610 Motherboard Replacement: 2 단계, 이미지 1/3 Nikon D610 Motherboard Replacement: 2 단계, 이미지 2/3 Nikon D610 Motherboard Replacement: 2 단계, 이미지 3/3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Motherboard Replacement: 3 단계, 이미지 1/2 Nikon D610 Motherboard Replacement: 3 단계, 이미지 2/2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
  4. Nikon D610 Motherboard Replacement, Outer Case: 4 단계, 이미지 1/1
    • After removal of the battery. Pull the battery compartment door away from the lens.
    • There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
    • Remove all the screws and the bottom face should pop off easily.
  5. Nikon D610 Motherboard Replacement: 5 단계, 이미지 1/3 Nikon D610 Motherboard Replacement: 5 단계, 이미지 2/3 Nikon D610 Motherboard Replacement: 5 단계, 이미지 3/3
    • Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
    • There are screws hidden in three separate spots.
    • One is under the rubber doors on the left side of the camera. the next one at the eye hole.
    • The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
    • Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
  6. Nikon D610 Motherboard Replacement: 6 단계, 이미지 1/2 Nikon D610 Motherboard Replacement: 6 단계, 이미지 2/2
    • The rear face plate will include the LCD display it separates from the body of the camera with a small tug.
    • Do not pull to hard otherwise you risk breaking the ribbon wire that connects the controls and the screen.
    • Once there is enough space it will be possible to gently pull the ribbon cable out of their ports.
  7. Nikon D610 Motherboard Replacement: 7 단계, 이미지 1/2 Nikon D610 Motherboard Replacement: 7 단계, 이미지 2/2
    • The next piece to come off is the front plate and the red grip.
    • The front plate is held on by 2 Philips #00 screws on the front and two more beneath the flash bulb.
    • Remove the two Phillips #00 screws holding on the grip and it slides off easily.
    • After removing the screws the face plate comes off by pulling it straight off to avoid damage.
  8. Nikon D610 Motherboard Replacement: 8 단계, 이미지 1/2 Nikon D610 Motherboard Replacement: 8 단계, 이미지 2/2
    • It is now possible to remove the last three Philips #00 screws that are hidden under the memory card slot door.
    • The screws come out and the cover comes straight off.
    • The last cover plate is the top. The top is held on by two screws located just beneath the rim of the cover.
    • The top should be pulled off very slowly. There are several electronic components that connect between the body and the top.
    • There are three wires that need to be disconnected.
  9. Nikon D610 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Nikon D610 Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • The rear side of the camera is where the motherboard is located. It is visible after you have taken off the rear face plate.
    • Remove the shield that protects it from static first.
    • This shield has six Philips #00 screws that are positioned around the edge of the shield.
    • After removal of the screws the shield will come free from the motherboard.
  10. Nikon D610 Motherboard Replacement: 10 단계, 이미지 1/2 Nikon D610 Motherboard Replacement: 10 단계, 이미지 2/2
    • The six screws that were removed in the previous step also hold the motherboard in place.
    • There are a few ribbon cables that connect to the motherboard to the rest of the camera with some of them hiding under other ribbon cables.
    • Be very careful when removing the ribbon wires. If they break it can cause problems with needing more repairs.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Eagan
회원 가입일: 02/10/16
606 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-4, Lacy Spring 2016 USF Tampa, Team 4-4, Lacy Spring 2016 회원
USFT-LACY-S16S4G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 2,691
