소개
If you get some CHA - errors on your Camera, it is likely time to replace the CF slot. The part number of the Nikon D70 CF slot is 1F998-181.
  1. Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
    • Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
  2. Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
    • Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
  3. Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket. Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Pull the LCD board ribbon cable out of its socket.
  4. Carefully pull the sides of the rear cover away from the body of the D70. Carefully pull the sides of the rear cover away from the body of the D70.
    • Carefully pull the sides of the rear cover away from the body of the D70.
  5. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  6. Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught. At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
    • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
    • At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  7. Remove the two Phillips screws securing the holder of the CF Card Slot. Remove the two Phillips screws securing the holder of the CF Card Slot.
    • Remove the two Phillips screws securing the holder of the CF Card Slot.
  8. Peel of the Foil securing the Flexcable.
    • Peel of the Foil securing the Flexcable.
  9. Use Tweezers to open the locking on the ribbon cable socket. Use Tweezers to open the locking on the ribbon cable socket.
    • Use Tweezers to open the locking on the ribbon cable socket.
  10. Pull the ribbon cable out of its socket. Pull the ribbon cable out of its socket.
    • Pull the ribbon cable out of its socket.
  11. Carefully fold the Pull the ribbon cable towards the CF Slot Carefully fold the Pull the ribbon cable towards the CF Slot
    • Carefully fold the Pull the ribbon cable towards the CF Slot
  12. Pull the Slot out of the body.
    • Pull the Slot out of the body.
  13. Remove the two Phillips screws to separate the Holder from the Slot. Remove the two Phillips screws to separate the Holder from the Slot.
    • Remove the two Phillips screws to separate the Holder from the Slot.
결론
다른 19명이 해당 안내서를 완성하였습니다.
joergkihm
회원 가입일: 2012년 06월 04일
692 평판
안내서 1개 작성함
Mine has a pin broken off. Where do I get a replacement?
Don Wirth - 답글
Hello,
Thanks to your help, I was able to replace it easily.
Many Thanks from France
Yan Elie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 22
지난 30일: 87
전체 시간: 22,318
