주요 콘텐츠로 건너뛰기
Nikon D70 CF Slot Replacement
필요한 것
  1. Nikon D70 CF Slot Replacement, Rear Cover Assembly: 1 단계, 이미지 1/1
    • Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
  2. Nikon D70 CF Slot Replacement: 2 단계, 이미지 1/1
    • Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
  3. Nikon D70 CF Slot Replacement: 3 단계, 이미지 1/2 Nikon D70 CF Slot Replacement: 3 단계, 이미지 2/2
    • Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Pull the LCD board ribbon cable out of its socket.
  4. Nikon D70 CF Slot Replacement: 4 단계, 이미지 1/2 Nikon D70 CF Slot Replacement: 4 단계, 이미지 2/2
    • Carefully pull the sides of the rear cover away from the body of the D70.
  5. Nikon D70 CF Slot Replacement: 5 단계, 이미지 1/2 Nikon D70 CF Slot Replacement: 5 단계, 이미지 2/2
    • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
    • At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  6. Nikon D70 CF Slot Replacement, D70 CF card slot replacement: 6 단계, 이미지 1/2 Nikon D70 CF Slot Replacement, D70 CF card slot replacement: 6 단계, 이미지 2/2
    • Remove the two Phillips screws securing the holder of the CF Card Slot.
  7. Nikon D70 CF Slot Replacement: 7 단계, 이미지 1/1
    • Peel of the Foil securing the Flexcable.
  8. Nikon D70 CF Slot Replacement: 8 단계, 이미지 1/2 Nikon D70 CF Slot Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use Tweezers to open the locking on the ribbon cable socket.
  9. Nikon D70 CF Slot Replacement: 9 단계, 이미지 1/2 Nikon D70 CF Slot Replacement: 9 단계, 이미지 2/2
    • Pull the ribbon cable out of its socket.
  10. Nikon D70 CF Slot Replacement: 10 단계, 이미지 1/2 Nikon D70 CF Slot Replacement: 10 단계, 이미지 2/2
    • Carefully fold the Pull the ribbon cable towards the CF Slot
  11. Nikon D70 CF Slot Replacement: 11 단계, 이미지 1/1
    • Pull the Slot out of the body.
  12. Nikon D70 CF Slot Replacement: 12 단계, 이미지 1/2 Nikon D70 CF Slot Replacement: 12 단계, 이미지 2/2
    • Remove the two Phillips screws to separate the Holder from the Slot.
결론
다른 24명이 해당 안내서를 완성하였습니다.
joergkihm
회원 가입일: 06/04/12
812 평판
안내서 1개 작성함
댓글 6개
Mine has a pin broken off. Where do I get a replacement?
Don Wirth - 답글
Hello,
Thanks to your help, I was able to replace it easily.
Many Thanks from France
Yan Elie - 답글
How do i change out the board with the pins…… second hand cam someone bent alot of pins
intimadationrc - 답글
I can order board or can i order the whole cf ?
intimadationrc -
You can find them on ebay real easy. both full assemblies and just the board with the pins
Steve Ancona -
Very nice photos and instructions definitely I will attempt after getting the replacement part.
Philip Yuen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 31
30일 전: 86
전체 시간: 27,385
