주요 콘텐츠로 건너뛰기
Nikon D70 DC/DC Board Replacement
필요한 것
  1. Nikon D70 DC/DC Board Replacement, Battery: 1 단계, 이미지 1/1
    • Use your finger tip to pull the battery release tab toward the center of the D70.
    • Open the battery door and rotate it away from the bottom cover.
  2. Nikon D70 DC/DC Board Replacement: 2 단계, 이미지 1/1
    • Pull the battery out of the D70.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon D70 DC/DC Board Replacement, Bottom Cover: 3 단계, 이미지 1/1
    • Remove the following eight screws securing the bottom cover to the D70:
    • Six 5.8 mm Phillips screws
    • One 10.7 mm Phillips screws
    • One 8.2 mm Phillips screws
  4. Nikon D70 DC/DC Board Replacement: 4 단계, 이미지 1/2 Nikon D70 DC/DC Board Replacement: 4 단계, 이미지 2/2
    • Carefully pull the bottom cover to separate it from the body of the D70.
    • Remove the bottom cover from the D70.
  5. Nikon D70 DC/DC Board Replacement, Memory Compression Board: 5 단계, 이미지 1/3 Nikon D70 DC/DC Board Replacement, Memory Compression Board: 5 단계, 이미지 2/3 Nikon D70 DC/DC Board Replacement, Memory Compression Board: 5 단계, 이미지 3/3
    • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
    • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
    • Be sure you are prying up the retaining flap, not the socket.
    • Pull the ribbon cable straight out of its socket.
  6. Nikon D70 DC/DC Board Replacement: 6 단계, 이미지 1/1
    • Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
    • It is not necessary to completely remove this piece of tape.
  7. Nikon D70 DC/DC Board Replacement: 7 단계, 이미지 1/3 Nikon D70 DC/DC Board Replacement: 7 단계, 이미지 2/3 Nikon D70 DC/DC Board Replacement: 7 단계, 이미지 3/3
    • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
    • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
    • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
  8. Nikon D70 DC/DC Board Replacement: 8 단계, 이미지 1/1
    • Be sure not to lose the small iron core around the DC-In ribbon cable.
  9. Nikon D70 DC/DC Board Replacement: 9 단계, 이미지 1/1
    • Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
  10. Nikon D70 DC/DC Board Replacement: 10 단계, 이미지 1/1
    • Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
  11. Nikon D70 DC/DC Board Replacement: 11 단계, 이미지 1/2 Nikon D70 DC/DC Board Replacement: 11 단계, 이미지 2/2
    • Grab the memory compression board by its edges at the position shown in the first picture.
    • Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
  12. Nikon D70 DC/DC Board Replacement, DC/DC Board: 12 단계, 이미지 1/1
    • Disconnect the DC-In board connector from the DC/DC board by pulling its connector away from the center of the board.
  13. Nikon D70 DC/DC Board Replacement: 13 단계, 이미지 1/2 Nikon D70 DC/DC Board Replacement: 13 단계, 이미지 2/2
    • Use your thumbnails to push the CCD connector out of its socket.
  14. Nikon D70 DC/DC Board Replacement: 14 단계, 이미지 1/2 Nikon D70 DC/DC Board Replacement: 14 단계, 이미지 2/2
    • Use your fingernail to carefully flip up the ZIF cable retaining flap for the ribbon cable socket near the front cover.
    • Be sure you are prying up on the movable cable retaining flap, not the socket itself.
    • Use a pair of tweezers to carefully pull the ribbon cable out of its socket.
  15. Nikon D70 DC/DC Board Replacement: 15 단계, 이미지 1/2 Nikon D70 DC/DC Board Replacement: 15 단계, 이미지 2/2
    • Use your fingernail to flip up the ZIF cable retaining flap on the socket near the battery opening.
    • Use a pair of tweezers to pull the ribbon cable out of its socket.
  16. Nikon D70 DC/DC Board Replacement: 16 단계, 이미지 1/1
    • Carefully de-solder the eight leads boxed in red.
    • Do not heat up the board excessively while de-soldering. There are many heat sensitive components mounted to the DC/DC board.
    • There are two black leads that look very similar. The thinner of the two connects closer to the center of the board.
  17. Nikon D70 DC/DC Board Replacement: 17 단계, 이미지 1/1
    • De-solder the positive and negative DC-In leads (boxed in red) from the DC/DC board.
    • Do not heat up the board excessively while de-soldering the leads.
  18. Nikon D70 DC/DC Board Replacement: 18 단계, 이미지 1/1
    • Remove the four 4.2 mm Phillips screws securing the DC/DC board to the D70.
  19. Nikon D70 DC/DC Board Replacement: 19 단계, 이미지 1/1
    • Remove the DC/DC board from the D70, minding any cables that may get caught.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
585,718 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 13,950
