소개
Replacing the DC/DC board requires a fine tipped soldering iron and knowledge of surface mount soldering.
필요한 것
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
Use your fingernail to flip up the ZIF cable retaining flap on each socket.
Pull the ribbon cable straight out of its socket.
Disconnect the DC-In board connector from the DC/DC board by pulling its connector away from the center of the board.
다른 7명이 해당 안내서를 완성하였습니다.
